Salta al contenuto principale
2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement
Cosa ti serve
  1. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: passo 1, immagine 1 di 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: passo 1, immagine 2 di 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: passo 1, immagine 3 di 3
    • Mount the new camera in the space provided.
    • The camera routes through the bumper of the car and not the license plate.
  2. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 2, immagine 1 di 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 2, immagine 2 di 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 2, immagine 3 di 3
    • Run the new wires through the holes provided, and cover with electrical tape.
    • The new cords will simply connect where the faulty wires were removed.
  3. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 3, immagine 1 di 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 3, immagine 2 di 3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 3, immagine 3 di 3
    • Coordinate the colored wires to keep the repair simple. Match the new wires to the existing wires through the splitter. Use a wire splitter to expose the wire.
    • Then simply connect the wires to the wires for reverse light.
  4. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 4, immagine 1 di 1
    • The green wire is the camera connection or positive wire and the black is the ground.
    • This line should already be connected correctly because you should have only switched wires that connected to the camera.
  5. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 5, immagine 1 di 1
    • Make sure that the reverse light is working properly when the car is in reverse.
  6. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 6, immagine 1 di 1
    • Make sure the display is clear and working properly.
Conclusione
Altre 2 persone hanno completato questa guida.
2 Commenti
The photos you show in steps 2 & 3 - is that the trunk only?
jrselinger24 - Replica
Hello. I am trying to replace my camera. But not sure how to remove it or where to buy a replacement.
Jonathan Anderson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 182
Tutti i Tempi: 13,046
