Salta al contenuto principale
2012-Present Toyota Corolla Windshield Wiper Replacement
Cosa ti serve
  1. 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: passo 1, immagine 1 di 2 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: passo 1, immagine 2 di 2
    • Lift up the windshield wiper you're replacing.
  2. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 2, immagine 1 di 2 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 2, immagine 2 di 2
    • Insert a flathead screwdriver into the locking mechanism of the wiper and gently pry it open.
    • You can use your car keys in case you do not have a screwdriver.
  3. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 3, immagine 1 di 2 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 3, immagine 2 di 2
    • Push the wiper blade downwards until it locks into place.
  4. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 4, immagine 1 di 2 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 4, immagine 2 di 2
    • Angle the wiper away from you, so that the top is near you while the bottom is farther away.
    • Gently push the blade out of the wiper base.
  5. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 5, immagine 1 di 2 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 5, immagine 2 di 2
    • Bring the new wiper blade into the wiper base from the car, aiming it so that the wiper base enters the lock hole.
    • Once the wiper blade is in, hold it from the bottom and push it upwards to secure the hold.
    • Make sure to start with the lock open, and that the blade is facing the same direction as the picture.
  6. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 6, immagine 1 di 3 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 6, immagine 2 di 3 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 6, immagine 3 di 3
    • Push down the lock with force until it clicks.
  7. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 7, immagine 1 di 1
    • Repeat for the second blade.
    • Your windshield wiper blade replacement is now complete!
Linea Traguardo
Yusuf Gabaire
Membro da: 07/03/21
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 130
Tutti i Tempi: 2,922
