Introduzione
Full replacement of a Driver side mirror on a 2012 Nissan Murano, SL options package.
  1. Pull out the Driver preset panel, if your options package included this. Usually no tools required.
    • Pull out the Driver preset panel, if your options package included this. Usually no tools required.
  2. Expose one of three screws by prying the door handle trim plate out.
    • Expose one of three screws by prying the door handle trim plate out.
  3. Pry out the door lock and window control panel. Disconnect all connectors on the back side. Pry out the door lock and window control panel. Disconnect all connectors on the back side. Pry out the door lock and window control panel. Disconnect all connectors on the back side.
    • Pry out the door lock and window control panel. Disconnect all connectors on the back side.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Pry up the arm rest to expose the second hidden screw (total of 3).
    • Pry up the arm rest to expose the second hidden screw (total of 3).
  6. Now you can remove all three hidden screws with the 10mm socket or philips screw driver.
    • Now you can remove all three hidden screws with the 10mm socket or philips screw driver.
    • Now the door panel itself can be pried off the door. Starting at the bottom, find the plastic friction plugs and pull enough to pop them out one by one.
    • Then lift the door panel up off the door. You do not need to remove it completly. This should give you enough room to work on the mirror in the next steps.
  7. Pull the inside mirror cover off. Pull the inside mirror cover off.
    • Pull the inside mirror cover off.
  8. Unplug the mirror wiring harness. The connector on the door will stay put.
    • Unplug the mirror wiring harness. The connector on the door will stay put.
  9. Remove the three nuts holding the mirror on to the door. Depending on the age of your vehicle, you may want to clean off the remaining area so the new mirror seals good.
    • Remove the three nuts holding the mirror on to the door. Depending on the age of your vehicle, you may want to clean off the remaining area so the new mirror seals good.
Conclusione
Altre 3 persone hanno completato questa guida.
Gajtguy
Membro da: 15/12/2013
177 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 43
Tutti i Tempi: 4,393
