Introduzione
This guide will show you how to change a damaged or worn out engine air filter in a 2012 Ford Fusion as quickly as possible.
In order to access the engines air filter, the hood must first be opened. To open the hood, begin by pulling the hood release latch.
Locate the air filter box, which is towards the front right side of the engine bay when looking towards the front of the car.
There are 2 retaining clips that hold the top half of the filter box to the lower half. they must be released to separate the halves.
In order to release them place your finger on the bottom lip and press upwards until it releases, which is denoted by a snapping sound.
Altre 5 persone hanno completato questa guida.
Un commento
I have a 2009 Ford fusion I have a 2009 Ford fusion, I have problems with the climate, if it turns on but it doesn't come out through the front ducts, is there any way to solve it?
