Salta al contenuto principale
2012-2015 Honda Civic Windshield Wiper Replacement
  1. 2012-2015 Honda Civic Windshield Wiper Replacement, Windshield Wipers: passo 1, immagine 1 di 1
    • Carefully pull the wipers upwards, away from the windshield.
  2. 2012-2015 Honda Civic Windshield Wiper Replacement: passo 2, immagine 1 di 3 2012-2015 Honda Civic Windshield Wiper Replacement: passo 2, immagine 2 di 3 2012-2015 Honda Civic Windshield Wiper Replacement: passo 2, immagine 3 di 3
    • Hold and press the first lever of the wiper arm down and put the wiper arm straight.
    • Pull the wiper up and slide the blade off of the arm.
    • Once the hook of the windshield looks like it went through the wiper, pull the wiper out leaving only the hook in place.
  3. 2012-2015 Honda Civic Windshield Wiper Replacement: passo 3, immagine 1 di 3 2012-2015 Honda Civic Windshield Wiper Replacement: passo 3, immagine 2 di 3 2012-2015 Honda Civic Windshield Wiper Replacement: passo 3, immagine 3 di 3
    • To install the new wiper blades, slide the hook onto the top space.
    • Then attached the hook to the center space of the wiper.
    • Lastly, gently press the wiper downward listening for a "click" or other indication for the blade is locked in place.
  4. 2012-2015 Honda Civic Windshield Wiper Replacement: passo 4, immagine 1 di 1
    • Turn on the wipers and test the new blades to make sure they are functioning correctly.
Conclusione
Congratulations! You have successfully replaced the windshield wipers on your Honda Civic 2015. With this step-by-step guide, you were able to complete the process with ease and without having to spend extra money at a mechanic. Having properly functioning wipers is crucial for your safety while driving, especially during rainy and snowy weather conditions. Now that you have completed this guide, you have the knowledge and confidence to replace your wipers in the future. Remember to periodically check your wipers and replace them as needed to ensure your safety on the road. Thank you for using this guide and happy driving!
Altre 2 persone hanno completato questa guida.
Un commento
Amazing work I now understand how to fix my windshield wipers :)
John Mejia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 85
Tutti i Tempi: 1,271
