Introduzione
If your rear turn signal light bulb in your 2012-2015 Honda Civic is not functioning, use this guide to replace the bulb in the taillight.
The turn signal allows you to communicate with other drivers on the road when you are turning, merging lanes, or (if both turn signals are used together) that you are in a hazardous situation and other drivers should use caution. If one of these turn signals are out, it could lead to miscommunication and dangerous consequences on the road.
Before utilizing this guide, ensure that the blown turn signal bulb is in one of the rear taillights. This guide is not for headlight bulbs. Ensure that all other turn signals and other bulbs in the taillight are working to ensure that it is indeed just a blown bulb.
Cosa ti serve
Ensure your car is turned off by checking that the key is in the off (O) position and that the engine is not running.
Open the trunk by pulling the latch on the floor of the driver's side.
The fasteners are easiest to reinstall when the center piece is pulled as far out as possible when reinserting. Once they are back in place, press the center piece down to lock them in.
