Salta al contenuto principale
2012-2015 Honda Civic Spark Plugs Replacement
Cosa ti serve
  1. 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: passo 1, immagine 1 di 3 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: passo 1, immagine 2 di 3 2012-2015 Honda Civic Spark Plugs Replacement, Spark Plugs: passo 1, immagine 3 di 3
    • Use a flathead screwdriver to remove the two screws holding the engine cover in place.
    • Remove the engine cover.
  2. 2012-2015 Honda Civic Spark Plugs Replacement: passo 2, immagine 1 di 2 2012-2015 Honda Civic Spark Plugs Replacement: passo 2, immagine 2 di 2
    • Locate the four spark plug connectors.
    • Insert a screwdriver into the space in the wire connector and lift the lid.
  3. 2012-2015 Honda Civic Spark Plugs Replacement: passo 3, immagine 1 di 3 2012-2015 Honda Civic Spark Plugs Replacement: passo 3, immagine 2 di 3 2012-2015 Honda Civic Spark Plugs Replacement: passo 3, immagine 3 di 3
    • Locate the bolt securing the ignition coil.
    • Use a wrench with a 10 mm socket to remove the bolt securing the ignition coil.
    • Once the bolt is removed, pull out the ignition coil.
  4. 2012-2015 Honda Civic Spark Plugs Replacement: passo 4, immagine 1 di 3 2012-2015 Honda Civic Spark Plugs Replacement: passo 4, immagine 2 di 3 2012-2015 Honda Civic Spark Plugs Replacement: passo 4, immagine 3 di 3
    • Locate the old spark plug.
    • Use a wrench with a spark plug socket (with a rubber grommet) to unscrew the spark plug.
    • Once the spark plug is unscrewed, pull out the wrench along with the spark plug.
  5. 2012-2015 Honda Civic Spark Plugs Replacement: passo 5, immagine 1 di 2 2012-2015 Honda Civic Spark Plugs Replacement: passo 5, immagine 2 di 2
    • Ensure that the new spark plug is dry.
    • Use a gap measuring tool to ensure that the spark plug gap is appropriate.
    • It is optional to lightly coat the threads with anti-seize to help remove them in the future.
    • Do not get anti-seize on the electrodes (the gap at the top of the threads).
  6. 2012-2015 Honda Civic Spark Plugs Replacement: passo 6, immagine 1 di 2 2012-2015 Honda Civic Spark Plugs Replacement: passo 6, immagine 2 di 2
    • Attach the new spark plug to the spark plug socket, and finger tighten the new spark plug.
    • Use the wrench to tighten the spark plug to 45 degrees.
    • Do not overtighten the spark plug.
    • Re-insert the ignition coil.
  7. 2012-2015 Honda Civic Spark Plugs Replacement: passo 7, immagine 1 di 2 2012-2015 Honda Civic Spark Plugs Replacement: passo 7, immagine 2 di 2
    • Use the wrench with the 10 mm socket to tighten the bolt that fastens the ignition coil.
    • Re-connect the wire connecter to the ignition coil.
Conclusione
Repeat steps for the remaining 3 spark plugs. Reattach the engine cover with the flathead screwdriver.
Altre 2 persone hanno completato questa guida.
Anthony
Membro da: 11/20/23
175 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 97
Ultimi 30 Giorni: 418
Tutti i Tempi: 3,178
