Salta al contenuto principale
2012-2016 Honda CR-V Oil and Oil Filter Replacement
Cosa ti serve
  1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, immagine 1 di 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, immagine 2 di 2
    • Open the hood by pulling the hood latch.
    • Oil may be hot if the engine has not cooled.
    • Keep vehicle in park and off unless otherwise noted.
    • Chock both back wheels with blocks of wood to prevent car from rolling.
  2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 2, immagine 1 di 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 2, immagine 2 di 2
    • Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
  3. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 3, immagine 1 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 3, immagine 2 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 3, immagine 3 di 3
    • Locate the dipstick and check oil level.
  4. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 4, immagine 1 di 1
    • Place the drain pain under the chassis and align with the drain bolt.
  5. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 5, immagine 1 di 1
    • Locate the drain bolt.
  6. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 6, immagine 1 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 6, immagine 2 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 6, immagine 3 di 3
    • Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
  7. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 7, immagine 1 di 1
    • Remove the oil filter with a 45mm oil filter socket.
  8. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 8, immagine 1 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 8, immagine 2 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 8, immagine 3 di 3
    • Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
  9. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 9, immagine 1 di 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 9, immagine 2 di 2
    • Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
  10. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 10, immagine 1 di 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 10, immagine 2 di 2
    • Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
  11. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 11, immagine 1 di 1
    • Replace the oil cap.
  12. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 12, immagine 1 di 1
    • Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
    • Stop the vehicle and let the engine rest for 5 minutes.
  13. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 13, immagine 1 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 13, immagine 2 di 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: passo 13, immagine 3 di 3
    • Use the dip stick to double check oil level and add more if needed.
    • Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
    • Reset the oil life in the maintenance section of the vehicle computer.
Conclusione
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 28
Ultimi 7 Giorni: 159
Ultimi 30 Giorni: 696
Tutti i Tempi: 22,271
