Salta al contenuto principale
2012-2018 Nissan Versa Note Headlight Bulb Replacement
Cosa ti serve
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 2 di 2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 2, immagine 1 di 1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 3, immagine 1 di 1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 4, immagine 1 di 1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 5, immagine 1 di 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 5, immagine 2 di 2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 6, immagine 1 di 1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 7, immagine 1 di 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 7, immagine 2 di 2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 8, immagine 1 di 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 8, immagine 2 di 2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 9, immagine 1 di 1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 10, immagine 1 di 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 10, immagine 2 di 2
    • Insert the connector into the bulb.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 65
Ultimi 30 Giorni: 262
Tutti i Tempi: 12,349
