Salta al contenuto principale
2011-2013 Scion tC Front Dome Light Replacement
Cosa ti serve
  1. 2011-2013 Scion tC Front Dome Light Replacement, Front Dome Light: passo 1, immagine 1 di 1
    • Remove the plastic covering of the lights by pulling it down quickly from the windshield side.
  2. 2011-2013 Scion tC Front Dome Light Replacement: passo 2, immagine 1 di 1
    • Disconnect the plastic header from system by pressing inward on the side tabs.
  3. 2011-2013 Scion tC Front Dome Light Replacement: passo 3, immagine 1 di 2 2011-2013 Scion tC Front Dome Light Replacement: passo 3, immagine 2 di 2
    • Turn blue knobs counter clockwise and pull to remove bulb housing.
  4. 2011-2013 Scion tC Front Dome Light Replacement: passo 4, immagine 1 di 2 2011-2013 Scion tC Front Dome Light Replacement: passo 4, immagine 2 di 2
    • Pull burnt bulb out of knob/housing.
    • When inserting the replacement, take note of the direction and polarity of the unit.
Conclusione
To reassemble the dome, follow these instructions in reverse order.
Cal Poly, Team 8-2, Regan Spring 2015 Membro di Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Membri
7 Guide realizzate
Un commento
I have been looking for how to remove the dome light assembly for awhile now! I felt that I was going to break the clips. Thanks for the great post!
Robert Killenberger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 37
Tutti i Tempi: 3,716
