Salta al contenuto principale
2011-2013 Scion tC Car Battery Replacement
Cosa ti serve
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: passo 1, immagine 1 di 1
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: passo 2, immagine 1 di 1
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: passo 3, immagine 1 di 1
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: passo 4, immagine 1 di 2 2011-2013 Scion tC Car Battery Replacement: passo 4, immagine 2 di 2
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: passo 5, immagine 1 di 2 2011-2013 Scion tC Car Battery Replacement: passo 5, immagine 2 di 2
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Conclusione
Cal Poly, Team 8-2, Regan Spring 2015 Membro di Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 41
Tutti i Tempi: 10,712
