Salta al contenuto principale
2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement
Cosa ti serve
  1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: passo 1, immagine 1 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: passo 1, immagine 2 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: passo 1, immagine 3 di 3
    • Make sure the car is off before you start your replacement. However, You don't have to disconnect the car battery.
    • Open the trunk first.
    • Using Phillips #2 screwdriver, remove the two 10 mm screws from the back & tail light.
  2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 2, immagine 1 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 2, immagine 2 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 2, immagine 3 di 3
    • Using both hands, carefully pull the brake & tail light off.
  3. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 3, immagine 1 di 1
    • Here is the tail light assembly.
    • The left one is for the brake light.
    • The right one is for the back-up light.
  4. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 4, immagine 1 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 4, immagine 2 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 4, immagine 3 di 3
    • Twist and turn the backup light to the right. And then pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the light bulb easily.
  5. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 5, immagine 1 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 5, immagine 2 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 5, immagine 3 di 3
    • Twist and turn the brake light to the right and pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the bulb easily.
  6. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 6, immagine 1 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 6, immagine 2 di 3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: passo 6, immagine 3 di 3
    • Replace the light bulbs.
    • Check that the light bulbs work first before replacing 10 mm screws.
Conclusione
Altre 2 persone hanno completato questa guida.
Adrian Ng
Membro da: 09/18/21
196 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 108
Tutti i Tempi: 4,299
