Salta al contenuto principale
2010 Jeep Liberty Headlight Bulb Replacement
Cosa ti serve
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 1
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, immagine 1 di 3 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, immagine 2 di 3 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, immagine 3 di 3
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, immagine 1 di 3 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, immagine 2 di 3 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, immagine 3 di 3
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: passo 4, immagine 1 di 1
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
Conclusione
Congratulations! You have a shiny new headlight.
Altre 8 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 45
Tutti i Tempi: 8,972
