Introduzione
This guide shows you how to remove a wheel and then reattach it for a 2010-2014 Ford Mustang.
Follow these guidelines to prevent harm to yourself or to others.
- Park the car on a firm and level surface.
- Turn off the engine and engage the emergency brake.
- The hydraulic jack should be in a good-working condition.
- The wheels should always be taken off one at a time when using a hydraulic jack.
Ricambi
Nessuna parte specificata.
Place the hydraulic jack under the metal frame of the car near the tire that you want to change.
Follow these instructions in reverse order to reassemble the wheel back to the vehicle.
Altre 5 persone hanno completato questa guida.
Un commento
I have found it to be better to loosen the wheel nuts before you jack up the car. Also, when replacing the wheel nuts, these must be torqued to the proper value. This requires the use of a torque wrench. Consult your manual for the proper torque on the wheel nuts.
