Salta al contenuto principale
2010-2014 Ford Mustang Spark Plug Replacement
Cosa ti serve
  1. 2010-2014 Ford Mustang Spark Plug Replacement, Spark Plug: passo 1, immagine 1 di 1
    • Open the hood and prop it open using the hood prop.
  2. 2010-2014 Ford Mustang Spark Plug Replacement: passo 2, immagine 1 di 1
    • Pull the red tab out of the electrical connector and slide the connector off of the coil pack.
  3. 2010-2014 Ford Mustang Spark Plug Replacement: passo 3, immagine 1 di 1
    • Remove the 10mm screw from the coil pack. Use the 10mm socket on the 3/8" drive ratchet to remove the screw.
  4. 2010-2014 Ford Mustang Spark Plug Replacement: passo 4, immagine 1 di 1
    • Remove the coil pack from cylinder.
  5. 2010-2014 Ford Mustang Spark Plug Replacement: passo 5, immagine 1 di 1
    • Loosen the spark plug completely using the 3/8" ratchet and extension with the 5/8" spark plug socket.
  6. 2010-2014 Ford Mustang Spark Plug Replacement: passo 6, immagine 1 di 1
    • Remove the spark plug from the cylinder using the grabber tool.
  7. 2010-2014 Ford Mustang Spark Plug Replacement: passo 7, immagine 1 di 1
    • Inspect the spark plug for blackening or other damage.
  8. 2010-2014 Ford Mustang Spark Plug Replacement: passo 8, immagine 1 di 1
    • Check the spark plug gap using the spark plug gap gauge. Make sure the gap is within desired specifications.
Conclusione
Altre 3 persone hanno completato questa guida.
4 Commenti
its a 9/16 socket for plugs for 3v heads( 05-10 mustangs gts) other than that great guide
CarGuy1991 - Replica
“To reassemble your device, follow these instructions in reverse order”
-_-
Wil Xavier - Replica
What about right bank, you have to take off the plemum should you disconnect the neg on battery before you restart the engine??
John - Replica
I agree. You have a whole lot more to do on the left side. You may even need new gaskets. May not be difficult but will take some time. Right side is easy peasy.
Lyndon “L J” J - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 130
Tutti i Tempi: 10,095
