Introduzione
Burned out tail lights may have severe effects on not only the person driving the vehicle, but on other drivers on the road. For example, a burned out tail light can delay the vehicle inspection process, which is a requirement for registration of a vehicle in Texas. A vehicle that is not properly registered in Texas will result in a citation, and possible towing of the vehicle.
Purchase the replacement bulb at an auto parts store. To find the correct bulb, ask the employee to look up the make and model of your mustang for the correct reverse light bulb.
Cosa ti serve
Open the trunk by either pushing the button to the left of the gear selector, or clicking the button twice on the keyfob.
Open the trunk.
To reattach the taillight to the wiring harness, do the reverse of step 4.
Turn the car on, press the brake, and put it in reverse to test the reverse light.
If the light turns on, continue to the conclusion.
If the light does not turn on, repeat steps 3, 5, and 6 to make sure the bulb is inserted correctly.
To reassemble your device, follow these instructions in reverse order from step 5.
Un commento
THANK YOU!! This worked Great and Thank Goodness you listed the Replacement Bulb Number 912, because none of the local auto parts store knew they had matching LED bulbs. They all had weird unknown unavailable halogen replacements. Duh. Works Great Now!! Thanks Much!! :-D Jeeeeeeeeeeeeeeeeeeeeeeeeeeeeeem :)
