Salta al contenuto principale
2010-2014 Ford Mustang Fuses Replacement
Cosa ti serve
  1. 2010-2014 Ford Mustang Fuses Replacement, Blown Fuse Replacement: passo 1, immagine 1 di 2 2010-2014 Ford Mustang Fuses Replacement, Blown Fuse Replacement: passo 1, immagine 2 di 2
    • Turn off the vehicle before beginning the fuse changing process to avoid electrocution.
    • Pull the hood release lever near the drivers feet to release the hood.
    • Move to the front of the vehicle.
    • Push the latch below the center of the hood to the left to unlock and open the hood.
    • Lift the hood and support it with the hood strut.
  2. 2010-2014 Ford Mustang Fuses Replacement: passo 2, immagine 1 di 1
    • The fuse box is located on the drivers side of the vehicle. It is a black rectangular box.
    • Open the fuse box by disengaging the latch on the left side of the fuse box by flipping it upwards or to the right.
  3. 2010-2014 Ford Mustang Fuses Replacement: passo 3, immagine 1 di 1
    • Referencing the Fuse Box Diagram, identify the blown fuse that needs replacement.
  4. 2010-2014 Ford Mustang Fuses Replacement: passo 4, immagine 1 di 2 2010-2014 Ford Mustang Fuses Replacement: passo 4, immagine 2 di 2
    • Remove the fuse that correspondences to the electrical failure in the vehicle by carefully pulling the fuse straight up and out of the fuse box.
    • It is safe to do this with your hands, just move slowly and carefully as you remove the blown fuse.
    • Check for damage or discoloration in the fuse.
    • Replace the damaged fuse with the new fuse by pushing it back into the appropriate fuse port. The new fuse should sit flush with the other fuses and may click when inserted correctly.
    • Close the fuse box and fasten latch on left side of fuse box.
Conclusione
To reassemble, follow these instructions in reverse order.
Cal Poly, Team 15-45, Forte Fall 2012 Membro di Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 Membri
6 Guide realizzate
Un commento
The fuse is stuck. How do I get it out.
Delia Gress - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 96
Ultimi 30 Giorni: 480
Tutti i Tempi: 18,720
