Salta al contenuto principale
2010-2014 Ford Mustang Air Filter Replacement
  1. 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: passo 1, immagine 1 di 2 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: passo 1, immagine 2 di 2
    • Make sure the vehicle is off before proceeding. Working under the cars hood can lead to burns if the car is still hot. Be careful!
    • Open the hood by pulling on the lever by the driver's feet.
    • Push upward on the latch under the center of the hood to unlock it.
  2. 2010-2014 Ford Mustang Air Filter Replacement: passo 2, immagine 1 di 1
    • Locate the Air Box
  3. 2010-2014 Ford Mustang Air Filter Replacement: passo 3, immagine 1 di 3 2010-2014 Ford Mustang Air Filter Replacement: passo 3, immagine 2 di 3 2010-2014 Ford Mustang Air Filter Replacement: passo 3, immagine 3 di 3
    • Locate the two latches that keep the air box closed.
    • Push on the latch to open the air box as shown in the picture, and repeat on the second latch.
    • Pull up on the top part of the air box and push it to the front of the car to open.
  4. 2010-2014 Ford Mustang Air Filter Replacement: passo 4, immagine 1 di 2 2010-2014 Ford Mustang Air Filter Replacement: passo 4, immagine 2 di 2
    • Make note of the orientation of the air filter before removing it.
    • Lift the filter straight up from the triangle corner and remove it.
  5. 2010-2014 Ford Mustang Air Filter Replacement: passo 5, immagine 1 di 2 2010-2014 Ford Mustang Air Filter Replacement: passo 5, immagine 2 di 2
    • Inspect for debris and dirt.
    • The first filter is dirty but does not need to be cleaned or replaced yet.
    • The second filter is dirty and does need to be cleaned or replaced
    • Do not discard the filter because it may be covered under a warranty.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 15-45, Forte Fall 2012 Membro di Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 36
Tutti i Tempi: 4,785
