Salta al contenuto principale
2010-2017 Suzuki Swift Tail Light Bulb Replacement
Cosa ti serve
  1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: passo 1, immagine 1 di 3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: passo 1, immagine 2 di 3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: passo 1, immagine 3 di 3
    • Unscrew the two visible bolts.
    • After unscrewing the bolts, the other side of the light is still fastened by two clickable plugs.
    • Using the panel removal tool, pry behind each corner and unclick each plug.
  2. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, access backside of the light: passo 2, immagine 1 di 1
    • Remove the light from the frame and place it on the tailgate.
    • You might need to remove some of the cabling from cable guides.
    • You can also better see the plugs that held the light in place.
  3. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, remove the fitting: passo 3, immagine 1 di 1
    • Unscrew the fitting about 45 degrees and lift it from the casing.
  4. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: passo 4, immagine 1 di 2 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: passo 4, immagine 2 di 2
    • Remove the bulb by turning it about 45 degrees.
    • And do the reverse with the new bulb, push and turn.
    • The bulb has 2 guide pins assuring a correct install.
    • The fitting has 2 corresponding receivers.
  5. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, insert fitting: passo 5, immagine 1 di 1
    • Insert the fitting by matching up the fitting guides with their openings on the casing and turn it 45 degrees clockwise.
  6. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, put the light back: passo 6, immagine 1 di 1
    • Tuck back any cables you loosened, and place the light back on the car frame.
    • Make sure the replaced light actually works.
    • Push the light plugs back in.
    • Put the 2 screws back in.
    • You are done.
Linea Traguardo
Altre 5 persone hanno completato questa guida.
knipwim
Membro da: 09/01/18
8.516 Reputazione
30 Guide realizzate
Un commento
Two bulbs not working
SATYANARAYANA VASAMSETTY - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 99
Ultimi 30 Giorni: 446
Tutti i Tempi: 34,686
