Salta al contenuto principale
2010-2017 Suzuki Swift Engine Air Filter Replacement
Cosa ti serve
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: passo 1, immagine 1 di 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: passo 1, immagine 2 di 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: passo 1, immagine 3 di 3
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: passo 2, immagine 1 di 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: passo 2, immagine 2 di 2
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: passo 3, immagine 1 di 1
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: passo 4, immagine 1 di 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: passo 4, immagine 2 di 2
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
Linea Traguardo
knipwim
Membro da: 09/01/18
8.527 Reputazione
30 Guide realizzate
Un commento
Thanks a lot
burakkurhan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 131
Tutti i Tempi: 6,333
