Salta al contenuto principale
2009 Toyota Corolla Headlight Bulb Replacement
Cosa ti serve
  1. 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 3 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 2 di 3 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 3 di 3
    • Wear gloves to avoid getting hands covered in engine grease.
    • Unlock the hood of the car by pulling the release located at the bottom-left side of the steering wheel.
    • Make sure to watch your hands for certain hazards, parts of the car may be sharp or hazardous.
  2. 2009 Toyota Corolla Headlight Bulb Replacement: passo 2, immagine 1 di 3 2009 Toyota Corolla Headlight Bulb Replacement: passo 2, immagine 2 di 3 2009 Toyota Corolla Headlight Bulb Replacement: passo 2, immagine 3 di 3
    • Open the hood and lock it in place.
    • Find the bulb near the inside of where the headlight is on the car (it should be located somewhere within the red circle). It will be attached to a wire.
    • Rotate the bulb until it becomes free and pull it out of the headlight casing.
  3. 2009 Toyota Corolla Headlight Bulb Replacement: passo 3, immagine 1 di 2 2009 Toyota Corolla Headlight Bulb Replacement: passo 3, immagine 2 di 2
    • Press and hold the button illustrated in the photo and pull the bulb apart from the wire. If the button is jammed, a screw driver may be necessary to press the button down with more force.
    • Be careful not to snap the bulb part from the connector when working to pull it out of the cable.
    • By now, the bulb should be separate from its container.
  4. 2009 Toyota Corolla Headlight Bulb Replacement: passo 4, immagine 1 di 1
    • Replace old bulb with new one by simply sliding it back onto the cable.
  5. 2009 Toyota Corolla Headlight Bulb Replacement: passo 5, immagine 1 di 1
    • Install the new bulb back into the headlight casing by turning clockwise until it is firmly connected as shown in the picture. Close the hood of the car.
    • Remember to realign the grooves on the bulb to match the connection with the headlight casing.
  6. 2009 Toyota Corolla Headlight Bulb Replacement: passo 6, immagine 1 di 1
    • Turn the car on and test your new headlight!
    • If the headlight doesn't work, turn car off and ensure the connection is correct with the headlight cable.
Conclusione
Talha
Membro da: 04/16/24
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 72
Tutti i Tempi: 166
