Salta al contenuto principale
Introduzione
Over time, your cabin air filter will become clogged with dust, leaves, hair, and other debris, leading to reduced cabin air flow. Toyota recommends replacing the cabin air filter every 10,000 miles, and charges a premium to do it. Follow this guide to replace your cabin air filter and save yourself money and time. Replacement will take about 5 minutes, and requires no tools. I used the STP CAF1816P cabin air filter found at a local auto parts store, but the Corolla will accept a variety of aftermarket cabin air filters, including the TYC 800025P and the FRAM CF10285.
Strumenti
Nessun attrezzo specificato.
  1. Get into the front passenger seat and open the lower glovebox. Get into the front passenger seat and open the lower glovebox.
    • Get into the front passenger seat and open the lower glovebox.
  2. Push the two side walls of the glovebox towards the center to free the stopper peg on each side. Push the two side walls of the glovebox towards the center to free the stopper peg on each side.
    • Push the two side walls of the glovebox towards the center to free the stopper peg on each side.
  3. Move to the right side of the glovebox and gently pop off the black retaining arm.
    • Move to the right side of the glovebox and gently pop off the black retaining arm.
  4. Gently lower the glovebox to the floor. It should hang in the position shown.
    • Gently lower the glovebox to the floor. It should hang in the position shown.
    What about the storage box above the glove box that blocks access to the filter? Is there enough room as shown to swing open the filter door access without removing the your box as well?
    John Shoaf - Replica
  5. Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away. Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away. Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away.
    • Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away.
  6. Pull the old cabin air filter out of the housing.
    • Pull the old cabin air filter out of the housing.
    • Cabin air flows top to bottom (your old filter should be dirty on the top to illustrate this). Some filters will have an arrow stating to point arrow up, while others will have the arrow go in the direction of the airflow, which would be down. Install new filter accordingly.
Linea Traguardo
Altre 24 persone hanno completato questa guida.
Geoff Wacker
Membro da: 30/09/2013
84.988 Reputazione
89 Guide realizzate
This is great! Thank you so much :) Saved $80
Erik Phillips - Replica
The direction of airflow is definitely from top to bottom. I stuck a piece of paper in while the cabin filter was out with fan running, it pulled the paper downward. Be careful not to let the paper go too low because it will hit the fan just a couple inches below the filter compartment.
tom.mcgathen - Replica
Very useful. TY
Virgil Caine - Replica
There is another air filter above this one. Anyone know how to remove it so it can be cleaned or replaced?
Wayne - Replica
I’m an 85 year old widow and I can follow these detailed instructions. Thank you very much.
Frances Pearce - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 92
Ultimi 30 Giorni: 418
Tutti i Tempi: 46,330
