Salta al contenuto principale
2009-2012 Toyota Corolla Cabin Air Filter Replacement
Cosa ti serve
  1. 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 2 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 2 di 2
    • Get into the front passenger seat and open the lower glovebox.
  2. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 2, immagine 1 di 2 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 2, immagine 2 di 2
    • Push the two side walls of the glovebox towards the center to free the stopper peg on each side.
  3. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 3, immagine 1 di 1
    • Move to the right side of the glovebox and gently pop off the black retaining arm.
  4. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 4, immagine 1 di 1
    • Gently lower the glovebox to the floor. It should hang in the position shown.
  5. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 5, immagine 1 di 3 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 5, immagine 2 di 3 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 5, immagine 3 di 3
    • Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away.
  6. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: passo 6, immagine 1 di 1
    • Pull the old cabin air filter out of the housing.
    • Cabin air flows top to bottom (your old filter should be dirty on the top to illustrate this). Some filters will have an arrow stating to point arrow up, while others will have the arrow go in the direction of the airflow, which would be down. Install new filter accordingly.
Linea Traguardo
Altre 30 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
89.953 Reputazione
89 Guide realizzate
8 Commenti
This is great! Thank you so much :) Saved $80
Erik Phillips - Replica
The direction of airflow is definitely from top to bottom. I stuck a piece of paper in while the cabin filter was out with fan running, it pulled the paper downward. Be careful not to let the paper go too low because it will hit the fan just a couple inches below the filter compartment.
tom.mcgathen - Replica
Very useful. TY
Virgil Caine - Replica
There is another air filter above this one. Anyone know how to remove it so it can be cleaned or replaced?
Wayne - Replica
I’m an 85 year old widow and I can follow these detailed instructions. Thank you very much.
Frances Pearce - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 344
Tutti i Tempi: 59,807
