Salta al contenuto principale
2009-2013 Kia Soul Turn Signal Bulb Replacement
Cosa ti serve
  1. 2009-2013 Kia Soul Turn Signal Bulb Replacement, Turn Signal bulb: passo 1, immagine 1 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement, Turn Signal bulb: passo 1, immagine 2 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement, Turn Signal bulb: passo 1, immagine 3 di 3
    • To access the battery and headlight, open the hood of the car.
    • Pull the lever near the foot pedals inside the car on the driver's side, to unlock the hood.
    • Use the hood lift support on the right side of the car to prop the hood open for repairs.
  2. 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 2, immagine 1 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 2, immagine 2 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 2, immagine 3 di 3
    • Make sure the engine is off and the car is in park before proceeding.
    • Remove the negative terminal cable from the battery by loosening the bolts on the clamp.
    • The connector should be able to slide off and be moved to the side.
  3. 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 3, immagine 1 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 3, immagine 2 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 3, immagine 3 di 3
    • Toward the front of the car, the headlight connector is attached to the back of the headlight.
    • Gently separate the connector from the socket.
  4. 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 4, immagine 1 di 2 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 4, immagine 2 di 2
    • Use a 10 mm socket wrench to remove the two 19 mm Hex body bolts that connect the headlight to the frame of the car.
    • They are located on top of the headlight above the connector cable.
  5. 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 5, immagine 1 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 5, immagine 2 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 5, immagine 3 di 3
    • Wiggle and pull the headlight to remove it from the frame of the car.
  6. 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 6, immagine 1 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 6, immagine 2 di 3 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 6, immagine 3 di 3
    • Gently place the headlight on the ground or place it on a blanket or soft surface to avoid scratching or cracking the plastic.
    • Pull the lightbulb holder out of the socket by twisting it clockwise and pulling outward slowly.
    • Be gentle when pulling out the lightbulb holder to avoid breaking the lightbulb.
  7. 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 7, immagine 1 di 2 2009-2013 Kia Soul Turn Signal Bulb Replacement: passo 7, immagine 2 di 2
    • Unscrew the bulb by twisting it clockwise and replace!
    • When replacing the lightbulb, don't touch the glass with your bare hand as the grease and salts can cause heat to concentrate. This could reduce the life of the bulb or cause it to shatter.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 129
Tutti i Tempi: 1,357
