Cosa ti serve
Open Hood: Open the hood using the hood latch inside the driver side of the car.
Pull lever to release the hood.
Disconnect Battery: Use an adjustable wrench to disconnect the negative power from the battery (Turn clockwise, then lift).
8 mm socket wrench
Tilt Mirror Forward and Disconnect Mirror: Locate lock tabs behind the mirror. Apply pressure to all three tabs until the mirror unlatches and you can remove it.
Unscrew Backing: Locate and unscrew 4 Torx T20 bolts holding backing and disconnect it from the mirror.
Two Torx T20 bolts.
Disconnect Old Mirror Blinking Light: Disconnect the plug from the rear of the blinker light.
Install New Mirror Blinker Light: Slide new light into the mirror and press firmly until you hear a click.
Reconnect Battery: Reconnect the negative power to the battery to restore power to the truck.
Test Blinker: Test your blinker to ensure the new setup works and reassemble your mirror.
