Salta al contenuto principale
2009 - 2014 Acura TSX Spark Plugs Replacement
Cosa ti serve
  1. 2009 - 2014 Acura TSX Spark Plugs Replacement, Spark Plugs: passo 1, immagine 1 di 2 2009 - 2014 Acura TSX Spark Plugs Replacement, Spark Plugs: passo 1, immagine 2 di 2
    • Pull the hood latch under the dashboard on the driver's side, to the left of your gas and brake pedal to open the hood of your Acura.
    • If your Acura has a hood prop rod, place it in the correct location. Most Acura's have hood lifts to help keep the hood in the up position.
  2. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 2, immagine 1 di 2 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 2, immagine 2 di 2
    • Using the 10mm socket, remove the four bolts from the cover where spark plugs are located.
    • Remove the cover and place it in a safe place for reassembly.
  3. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 3, immagine 1 di 2 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 3, immagine 2 di 2
    • Use your thumb to push down the latch with your thumb and pull the connector
    • Don't pull the connector without pressing the latch.
  4. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 4, immagine 1 di 3 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 4, immagine 2 di 3 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 4, immagine 3 di 3
    • Use a 10 mm socket to remove the bolts that are securing the coils.
    • Pull the ignition coils out.
    • Place Ignition Coils in order the way you have pulled them out.
  5. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 5, immagine 1 di 2 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 5, immagine 2 di 2
    • Use the ratchet extension and 5/8" socket to reach the spark plug and loosen it.
    • Rotate it counter-clockwise.
    • Pull the extension up and the spark plug should come up attached to the socket.
  6. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 6, immagine 1 di 1
    • Check the old spark plug gap using the spark plug gap gauge.
    • Inspect the old spark plug for blackening or other damage.
    • The new spark plugs should come pre-gapped and have a cardboard cylindrical sleeve protecting the electrode/air gap.
  7. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 7, immagine 1 di 1
    • Insert the new spark plug in the 5/8" spark plug socket and screw it in by hand first.
    • Rotate it clockwise.
    • Tighten with only the extension and hand. Then attach the ratchet after to gently tighten it.
    • Do not screw the spark plugs in too tight.
  8. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 8, immagine 1 di 2 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 8, immagine 2 di 2
    • Insert the coil packs into the chamber.
    • Press down on them firmly so that they sit nicely on the top of the plug.
    • Use the 10 mm deep socket with a wrench and put the 10 mm bolts back in to hold the coils in place and tighten them.
  9. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 9, immagine 1 di 1
    • Reattach the wire connectors.
    • Press the connectors in, and they will click into place.
  10. 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 10, immagine 1 di 2 2009 - 2014 Acura TSX Spark Plugs Replacement: passo 10, immagine 2 di 2
    • Put the engine cover back on.
    • Insert 4 x 10mm bolts into their place and tighten them with a 10 mm hex driver or socket.
Conclusione
Before you spend hundreds of dollars to a professional to replace your plugs and coils, check out our step-by-step instructions above and save some money by doing it yourself.
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 87
Tutti i Tempi: 3,402
