Salta al contenuto principale
2008 Toyota Corolla Battery Replacement
Cosa ti serve
  1. 2008 Toyota Corolla Battery Replacement, Battery: passo 1, immagine 1 di 2 2008 Toyota Corolla Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Open the car hood.
    • The battery will be located on the bottom right.
  2. 2008 Toyota Corolla Battery Replacement: passo 2, immagine 1 di 2 2008 Toyota Corolla Battery Replacement: passo 2, immagine 2 di 2
    • There are two terminals on the battery. The positive terminal is on the left with the red cover. The negative terminal is on the right.
    • Unscrew the bolt to loosen the negative terminal.
    • Remove the negative terminal from the battery.
  3. 2008 Toyota Corolla Battery Replacement: passo 3, immagine 1 di 2 2008 Toyota Corolla Battery Replacement: passo 3, immagine 2 di 2
    • Take the red cover off the positive terminal.
    • Unscrew the bolt to remove the positive terminal.
    • Loosening the screws of the terminal can be difficult. In the first picture, I used pliers to help loosen up the screw holding the terminal tight.
  4. 2008 Toyota Corolla Battery Replacement: passo 4, immagine 1 di 3 2008 Toyota Corolla Battery Replacement: passo 4, immagine 2 di 3 2008 Toyota Corolla Battery Replacement: passo 4, immagine 3 di 3
    • Disconnect the battery's terminals from the battery, and remove the old battery.
    • Batteries, over time, tend to get dirty. You can mix baking soda with water and use a brush to clean your terminals.
  5. 2008 Toyota Corolla Battery Replacement: passo 5, immagine 1 di 3 2008 Toyota Corolla Battery Replacement: passo 5, immagine 2 di 3 2008 Toyota Corolla Battery Replacement: passo 5, immagine 3 di 3
    • Once everything is clean, you can begin installing your new battery.
    • Install your new battery in the correct space. You will install the negative terminal first, then the positive terminal.
    • Before moving on, make sure each screw on the terminal is tight and secured.
  6. 2008 Toyota Corolla Battery Replacement: passo 6, immagine 1 di 1
    • Ensure that every bolt is secured.
    • Start your car and let your car run for a couple of minutes.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Lair Noriega
Membro da: 04/04/22
237 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 141
Tutti i Tempi: 4,128
