Salta al contenuto principale
2008 Suzuki SX4 Brake Light Replacement
Cosa ti serve
  1. 2008 Suzuki SX4 Brake Light Replacement, Brake Light: passo 1, immagine 1 di 3 2008 Suzuki SX4 Brake Light Replacement, Brake Light: passo 1, immagine 2 di 3 2008 Suzuki SX4 Brake Light Replacement, Brake Light: passo 1, immagine 3 di 3
    • Power off your vehicle before beginning the replacement.
    • With your vehicle in PARK, engage the emergency parking brake.
    • Turn off your vehicle and make sure all light switches are set to OFF.
  2. 2008 Suzuki SX4 Brake Light Replacement: passo 2, immagine 1 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 2, immagine 2 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 2, immagine 3 di 3
    • Press the button located under the rear handle and above the license plate to open the hatch.
    • Open the hatch fully to expose the screws on the side of the brake light housing.
    • Open the hatch wide enough to give yourself some space while working on this replacement.
  3. 2008 Suzuki SX4 Brake Light Replacement: passo 3, immagine 1 di 2 2008 Suzuki SX4 Brake Light Replacement: passo 3, immagine 2 di 2
    • Using a Phillips head screwdriver, remove the two 5 mm bolts from the side of the brake light housing.
  4. 2008 Suzuki SX4 Brake Light Replacement: passo 4, immagine 1 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 4, immagine 2 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 4, immagine 3 di 3
    • There are two clips behind the housing.
    • Be gentle when removing the brake light housing. The two clips behind the housing can break easily if you are not careful!
    • Gently pull the brake light housing towards you until it detaches from your car.
  5. 2008 Suzuki SX4 Brake Light Replacement: passo 5, immagine 1 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 5, immagine 2 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 5, immagine 3 di 3
    • The bulbs can reach high temperatures during operation. Do not handle the bulbs if your vehicle has been in use recently!
    • Twist each bulb-connector to the left to unfasten the bulb from the housing.
    • Repeat this step for each bulb so that you can fully remove the housing.
    • This will give you better access to each bulb.
  6. 2008 Suzuki SX4 Brake Light Replacement: passo 6, immagine 1 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 6, immagine 2 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 6, immagine 3 di 3
    • The brake light bulb has a nougat-colored connector.
    • Remove the brake light bulb from its connector by pulling it out of the socket.
    • Do not put too much pressure on the bulb with your hands. It is fragile and can shatter easily.
  7. 2008 Suzuki SX4 Brake Light Replacement: passo 7, immagine 1 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 7, immagine 2 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 7, immagine 3 di 3
    • Place the new bulb into the socket.
    • If you are replacing the brake light with an LED Fog Light, ensure it is facing the correct orientation.
    • Unlike halogen bulbs, LED Bulbs only function when oriented correctly. You may need to reverse the orientation if the bulb is not functioning.
  8. 2008 Suzuki SX4 Brake Light Replacement: passo 8, immagine 1 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 8, immagine 2 di 3 2008 Suzuki SX4 Brake Light Replacement: passo 8, immagine 3 di 3
    • To ensure your bulbs are fully functional, depress the brake pedal. Doing this will make the brake lights turn on.
    • Make sure the light bulb turns on. This will also make sure your LED light is working properly.
    • Do not hold the brake pedal for too long as it will raise the temperature of the bulb to a dangerous level. Always wait for the bulb to cool down before handling it.
Conclusione
To reassemble the housing, follow these instructions in reverse order. Once everything is reassembled, turn on all your vehicle lights and ensure all rear lights are functioning.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 82
Tutti i Tempi: 274
