Salta al contenuto principale
2008 Subaru Impreza Windshield Wiper Arm Adjustment
Cosa ti serve
  1. 2008 Subaru Impreza Windshield Wiper Arm Adjustment, 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 1, immagine 1 di 1
    • To begin, pop open your hood for best access.
  2. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 2, immagine 1 di 1
    • There will be a rectangular bolt cover on the end of the wiper arm.
    • To remove this cover, grab each side with your fingers and pull upward.
    • It may help to wedge your fingernails underneath the cover piece.
  3. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 3, immagine 1 di 1
    • After removing the bolt cover, you will find the bolt that holds the wiper arm onto the vehicle.
  4. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 4, immagine 1 di 1
    • Loosen the bolt with the socket wrench just enough to be able to move the arm up and down the windshield.
    • To loosen with the wrench, place the socket directly on top of the bolt and turn counter clockwise.
  5. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 5, immagine 1 di 1
    • Adjust the windshield wiper arm such that it is in the proper resting position.
  6. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 6, immagine 1 di 1
    • There should be approximately 2 inches of space between the bottom of the windshield and the wiper in proper resting position.
  7. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 7, immagine 1 di 1
    • Once the arm is in correct position, tighten the same bolt at the bottom of the arm to keep the wiper in place.
    • To tighten the bolt, place the socket directly on top of the bolt and turn in clockwise position until you are no longer able to turn.
  8. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 8, immagine 1 di 1
    • Place the bolt cover back over the bolt and push it down into clipped position.
  9. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: passo 9, immagine 1 di 1
    • Close the hood of the vehicle. Your windshield wiper should now be in the correct position.
Conclusione
This guide will allow you to adjust both of the front windshield wipers. To realign the passenger side wiper, follow these steps in correct order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 4,216
