Salta al contenuto principale
2008 Honda Pilot Tail Light Assembly Replacement
Cosa ti serve
  1. 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: passo 1, immagine 1 di 2 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: passo 1, immagine 2 di 2
    • Open the vehicle's trunk to see the two bolts holding the assembly to the body.
    • Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
    • Save the bolts! They will be needed for installing the new assembly.
  2. 2008 Honda Pilot Tail Light Assembly Replacement: passo 2, immagine 1 di 2 2008 Honda Pilot Tail Light Assembly Replacement: passo 2, immagine 2 di 2
    • Place both hands on the assembly and pull it away from the vehicle.
    • There are two clips on the back of the assembly that are connecting it to the vehicle. They will disengage if the assembly is pulled with adequate force.
    • If the clips won't disengage try using a rocking motion while pulling on the assembly.
  3. 2008 Honda Pilot Tail Light Assembly Replacement: passo 3, immagine 1 di 3 2008 Honda Pilot Tail Light Assembly Replacement: passo 3, immagine 2 di 3 2008 Honda Pilot Tail Light Assembly Replacement: passo 3, immagine 3 di 3
    • Unlock the three light sockets connected to the assembly by twisting them counter clockwise.
    • Pull the light sockets out of the assembly.
  4. 2008 Honda Pilot Tail Light Assembly Replacement: passo 4, immagine 1 di 3 2008 Honda Pilot Tail Light Assembly Replacement: passo 4, immagine 2 di 3 2008 Honda Pilot Tail Light Assembly Replacement: passo 4, immagine 3 di 3
    • Set the old assembly aside.
    • Take the new assembly, and put the light bulb sockets into their corresponding holes.
    • Twist each socket clockwise to lock them into place.
  5. 2008 Honda Pilot Tail Light Assembly Replacement: passo 5, immagine 1 di 3 2008 Honda Pilot Tail Light Assembly Replacement: passo 5, immagine 2 di 3 2008 Honda Pilot Tail Light Assembly Replacement: passo 5, immagine 3 di 3
    • Line the clips on the back of assembly up with their holes, and push the assembly into place.
    • Take the bolts from Step 2 and place them into the holes on the new assembly. Twist them clockwise until secure.
  6. 2008 Honda Pilot Tail Light Assembly Replacement: passo 6, immagine 1 di 1
    • Congratulations! You have installed a new tail light assembly on your vehicle!
Conclusione
Congratulations! You have successfully completed the guide! Enjoy your new tail light assembly.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 651
