Introduzione
Tired of driving with a broken radio in your Mitsubishi Lancer and you don’t want to spend a small fortune having it replaced at a dealership? Save yourself the labor costs and simply do it yourself following this step-by-step guide.
In this guide I will be replacing the radio unit for a 2008 Mitsubishi Lancer. The model and part number of the radio unit may vary with year.
The model/part number for the radio unit is: MN141319/DY-3W69U
This guide may not apply to models with Rockford Fosgate or navigation systems.
Cosa ti serve
The only tool required for this install is a Phillips #2 screwdriver. Of course, you will also need the new replacement radio/CD player unit that you will be installing.
Altre 4 persone hanno completato questa guida.
5 Commenti
Any Mitsubishi radio code can be recovered for free by online generating tool : https://www.radiocodescalculator.com/mit...
Hi I own a 2008 Mitsubishi lancer just brought it CD player doesn't work only radio so wondering where I can buy a new stereo thanks. Or a way to fix mine it's like it's not working at all turn onto CD mode but won't even try read
Had the same problem with my 08 lancer. Replaced with a refurbished unit.
