Salta al contenuto principale
2008-2012 Honda Accord Headlight Bulb Replacement
Cosa ti serve
  1. 2008-2012 Honda Accord Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 1
    • (Right Side Headlight)
    • Turn the wheel all the way inward to have enough clearance.
    • Turn the vehicle fully off before proceeding to the next step.
  2. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 2, immagine 1 di 3 2008-2012 Honda Accord Headlight Bulb Replacement: passo 2, immagine 2 di 3 2008-2012 Honda Accord Headlight Bulb Replacement: passo 2, immagine 3 di 3
    • Locate the inner fender's retainer clips.
    • Using a flat-head screwdriver, pry out the retainer clips.
  3. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 3, immagine 1 di 1
    • Pry back the inner fender liner to gain access to the headlight bulb.
    • An object may be needed to keep the fender liner pulled back
  4. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 4, immagine 1 di 3 2008-2012 Honda Accord Headlight Bulb Replacement: passo 4, immagine 2 di 3 2008-2012 Honda Accord Headlight Bulb Replacement: passo 4, immagine 3 di 3
    • Locate the headlight bulb, and turn the item clockwise so that it points towards the engine.
    • For the left bulb, turn the item counter clock-wise
  5. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 5, immagine 1 di 2 2008-2012 Honda Accord Headlight Bulb Replacement: passo 5, immagine 2 di 2
    • Pull out the headlight bulb from its socket.
    • Be careful while pulling the bulb out, you might damage the bulb or its connected cable.
  6. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 6, immagine 1 di 3 2008-2012 Honda Accord Headlight Bulb Replacement: passo 6, immagine 2 di 3 2008-2012 Honda Accord Headlight Bulb Replacement: passo 6, immagine 3 di 3
    • For a more visible view of this step since the space is small and cluttered. -Credit for these 3 pictures: @PrecisionLED
    • To disconnect the bulb, pinch the top of the white block to release it from the bulb
    • When installing a new bulb, be careful while handling the bulb to not smudge or damage the bulb.
Conclusione
Carson Nguyen
Membro da: 10/23/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 115
Ultimi 30 Giorni: 442
Tutti i Tempi: 2,829
