Salta al contenuto principale
2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement
Cosa ti serve
  1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement, Washer Nozzle: passo 1, immagine 1 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement, Washer Nozzle: passo 1, immagine 2 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement, Washer Nozzle: passo 1, immagine 3 di 3
    • Unlatch the hood from the inside of your car.
    • If you're doing this right after driving your car, turn off the engine and let it cool down before working on it.
    • Put your fingers under the hood and lift the lever. With your other hand, raise the hood up.
    • The hood should rest on the support rod on its own; you can now remove the hand that was initially supporting the hood.
  2. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 2, immagine 1 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 2, immagine 2 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 2, immagine 3 di 3
    • Remove all pins from the cover by firmly bending them out of the hood
    • You can use a mask to prevent inhaling dirt from the cover
  3. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 3, immagine 1 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 3, immagine 2 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 3, immagine 3 di 3
    • Detach the pressure hose from the washer nozzle.
    • After detaching, examine the pressure hose for any debris that may have accumulated from the old washer nozzle.
  4. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 4, immagine 1 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 4, immagine 2 di 3 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 4, immagine 3 di 3
    • Use pliers to compress the tabs that hold the nozzles in place.
    • The tabs will be located at the top and bottom of the nozzle from the hood.
    • Once compressed, firmly grip the nozzle at the top and pull it away
  5. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 5, immagine 1 di 1
    • Carefully insert the new washer nozzle into the top of the hood, applying gentle pressure until it snaps securely into place.
  6. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 6, immagine 1 di 2 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 6, immagine 2 di 2
    • After inserting the washer nozzle, double-check from inside the hood to ensure that the tabs are firmly gripping the hood
    • Re-attach the hose to the nozzle.
  7. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 7, immagine 1 di 2 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: passo 7, immagine 2 di 2
    • To re-attach the cover push the pins on the cover into the coresponding holes
Conclusione
Mamoudou Balde
Membro da: 03/21/24
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 159
Tutti i Tempi: 193
