Salta al contenuto principale
2008 - 2020 Dodge Caravan Headlight Bulb Replacement
Cosa ti serve
  1. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement, Headlight bulb: passo 1, immagine 1 di 1
    • Park the car on a level surface.
    • Turn off the car and put on the emergency break for extra safety.
  2. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 2, immagine 1 di 2 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 2, immagine 2 di 2
    • Lift the hood release on the drivers side seat, near the foot pedals.
    • Open the hood latch and lift the hood up until it stays open on its own.
    • The headlight socket is located along inside edge of the hood.
  3. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 3, immagine 1 di 3 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 3, immagine 2 di 3 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 3, immagine 3 di 3
    • At the rear of the headlight assembly, rotate the bulb in a counterclockwise direction to detach it from the socket.
    • Release the clips on both sides and take it out from the wiring harness.
    • Insert the new bulb into the harness. You will know it is complete when you feel the clips attaching.
    • Don't touch the bulb with your bare hands. The oils and salt from your hands will reduce the life of the bulb and possibly damage it.
  4. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 4, immagine 1 di 1
    • Align the tabs on the socket with the opening on the back to reinstall it.
    • Turn the socket clockwise to secure it.
  5. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 5, immagine 1 di 2 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: passo 5, immagine 2 di 2
    • Close the hood.
    • Test out your new lights.
    • To view the lights better, test them out at night.
Conclusione
To replace other lights, follow the same guide.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 83
Tutti i Tempi: 744
