Salta al contenuto principale
2007 Toyota Yaris Cabin Air Filter Replacement
Cosa ti serve
  1. 2007 Toyota Yaris Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 2 2007 Toyota Yaris Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 2 di 2
    • Locate and open the glove compartment.
  2. 2007 Toyota Yaris Cabin Air Filter Replacement: passo 2, immagine 1 di 1
    • Remove the glove compartment by squeezing the sides closer until you are able to remove the compartment.
  3. 2007 Toyota Yaris Cabin Air Filter Replacement: passo 3, immagine 1 di 2 2007 Toyota Yaris Cabin Air Filter Replacement: passo 3, immagine 2 di 2
    • Pinch and pull the compartment that leads to the old air filter.
    • Remove the compartment completely and place it to the side.
  4. 2007 Toyota Yaris Cabin Air Filter Replacement: passo 4, immagine 1 di 1
    • Remove the air filter from the compartment.
  5. 2007 Toyota Yaris Cabin Air Filter Replacement: passo 5, immagine 1 di 3 2007 Toyota Yaris Cabin Air Filter Replacement: passo 5, immagine 2 di 3 2007 Toyota Yaris Cabin Air Filter Replacement: passo 5, immagine 3 di 3
    • Insert the new air filter.
    • Place the compartment back in position to cover the air filter.
    • Push the ridges back into place.
  6. 2007 Toyota Yaris Cabin Air Filter Replacement: passo 6, immagine 1 di 1
    • Lean the glove compartment back into place.
  7. 2007 Toyota Yaris Cabin Air Filter Replacement: passo 7, immagine 1 di 1
    • Push the glove box back to its natural state and enjoy your new air filter!
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 216
Tutti i Tempi: 495
