Introduzione
This is the perfect guide if you're looking to replace stock speakers with a nicer set, or if you've blown out your current speakers in your Mazda 6. Speakers are fairly easy to replace as long as you aren't completely rewiring the system.
Cosa ti serve
Pop open the hood and locate the battery.
Loosen the bolt on the positive terminal with the 10mm wrench.
Pull up and detach the terminal to disrupt power flow.
