Salta al contenuto principale
Introduzione
I wanted more than anything to give my children a good Christmas so I bought my daughter new speakers for her car. Then in order to get me to install them I chose to create a fast fix guide. You will find comprehensive instructions here to install new speakers and amplifier into the trunk of a 2007 accord. It may seem daunting at first but take it one step at a time and remember anything can be overcome with hard work, a little know how, and a bunch of money.
  1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: passo 1, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: passo 1, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: passo 1, immagine 3 di 3
    • Using plastic opening tools, remove the floor trim panel on the driver's side door.
  2. 2007 Honda Accord Bass Speakers Replacement: passo 2, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 2, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 2, immagine 3 di 3
    • Remove the shifter frame panel with the same opening tools.
  3. 2007 Honda Accord Bass Speakers Replacement: passo 3, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 3, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 3, immagine 3 di 3
    • Unclip the heated seats harnesses.
    • Remove the 12V power supply connection.
  4. 2007 Honda Accord Bass Speakers Replacement: passo 4, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 4, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 4, immagine 3 di 3
    • Remove the cubby space to access the head unit.
  5. 2007 Honda Accord Bass Speakers Replacement: passo 5, immagine 1 di 2 2007 Honda Accord Bass Speakers Replacement: passo 5, immagine 2 di 2
    • Remove the center climate vents with the opening tools.
  6. 2007 Honda Accord Bass Speakers Replacement: passo 6, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 6, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 6, immagine 3 di 3
    • Remove the head unit from the dash.
  7. 2007 Honda Accord Bass Speakers Replacement: passo 7, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 7, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 7, immagine 3 di 3
    • Attach the wiring harness into the amp by clipping it in.
  8. 2007 Honda Accord Bass Speakers Replacement: passo 8, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 8, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 8, immagine 3 di 3
    • Run the wires under the back seat and along the driver's side door sill (removed in step 1) to under the steering wheel.
  9. 2007 Honda Accord Bass Speakers Replacement: passo 9, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 9, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 9, immagine 3 di 3
    • Find a spot to drill a hole through the firewall under steering wheel area in the footwell.
  10. 2007 Honda Accord Bass Speakers Replacement: passo 10, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 10, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 10, immagine 3 di 3
    • Run the power and ground wires from the trunk through the door sill and through the firewall to the engine bay.
  11. 2007 Honda Accord Bass Speakers Replacement: passo 11, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 11, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 11, immagine 3 di 3
    • Now run the power wire where it will be out of the way.
    • Run the power wire (red) and the ground wire (green) to battery, connect red to positive and green ground to a clean piece of the car body.
    • Make sure to leave the power wire off until finished.
  12. 2007 Honda Accord Bass Speakers Replacement: passo 12, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 12, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 12, immagine 3 di 3
    • Remove the wiring harness from the back of the head unit.
    • Connect the four speaker wires and one remote wire to the harness as suggested in the owner's manual.
  13. 2007 Honda Accord Bass Speakers Replacement: passo 13, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 13, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 13, immagine 3 di 3
    • Clamp down the wire harness on the five wires.
    • Tape up the wire loom to keep it neat.
    • Finally insert it back into the head unit.
  14. 2007 Honda Accord Bass Speakers Replacement: passo 14, immagine 1 di 3 2007 Honda Accord Bass Speakers Replacement: passo 14, immagine 2 di 3 2007 Honda Accord Bass Speakers Replacement: passo 14, immagine 3 di 3
    • At last put the head unit, and the panels back into the car.
Conclusione
To reassemble your device, follow the instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Frankie
Membro da: 24/03/2021
253 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 121
Tutti i Tempi: 1,204
