Salta al contenuto principale
2007-2011 Toyota Yaris Drip Rail Replacement
Cosa ti serve
  1. 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: passo 1, immagine 1 di 3 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: passo 1, immagine 2 di 3 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: passo 1, immagine 3 di 3
    • Peel back the old molding from where it is beginning to come off until you reach the end of the rail.
  2. 2007-2011 Toyota Yaris Drip Rail Replacement: passo 2, immagine 1 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 2, immagine 2 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
    Compra
    • Use a heavy duty spudger to disconnect the end of the drip rail.
    • It may be connected at the end pretty tightly so it could take some work to remove.
    • Completely remove the piece from the end.
  3. 2007-2011 Toyota Yaris Drip Rail Replacement: passo 3, immagine 1 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 3, immagine 2 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 3, immagine 3 di 3
    • Take a rag and clean out any dirt and debris that built up under the old molding.
  4. 2007-2011 Toyota Yaris Drip Rail Replacement: passo 4, immagine 1 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 4, immagine 2 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 4, immagine 3 di 3
    • Slide the end of the new piece into the designated spot and press firmly to ensure it's connected securely.
    • Lightly tug at it to make it is secure and won't come off.
    • Do the same to the opposite end of the drip rail.
    • The molding for the left and right drip rails are different parts.
  5. 2007-2011 Toyota Yaris Drip Rail Replacement: passo 5, immagine 1 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 5, immagine 2 di 3 2007-2011 Toyota Yaris Drip Rail Replacement: passo 5, immagine 3 di 3
    • Firmly press the drip rail into its place starting at one end and moving down the car.
    • Check to make sure the new drip rail is thoroughly sealed to the car.
Conclusione
Isabel Sagheb
Membro da: 04/19/23
121 Reputazione
1 Guida realizzata
UC Davis, Team 2-2, Morris Spring 2023 Membro di UC Davis, Team 2-2, Morris Spring 2023
UCD-MORRIS-S23S2G2
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 76
Tutti i Tempi: 757
