Salta al contenuto principale
2007-2012 Jeep Wrangler Headlight Replacement
Cosa ti serve
  1. 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: passo 1, immagine 1 di 2 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: passo 1, immagine 2 di 2
    • Locate the two gray latches on either side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Headlight Replacement: passo 2, immagine 1 di 2 2007-2012 Jeep Wrangler Headlight Replacement: passo 2, immagine 2 di 2
    • Reach under the hood and push the lever left to right. You should now be able to lift the hood.
    • Prop open the hood by inserting the support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Headlight Replacement: passo 3, immagine 1 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 3, immagine 2 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 3, immagine 3 di 3
    • Locate all six push on fasteners on the top of the grill.
    • Use a flathead screwdriver to pry up the fasteners, and make sure you put the screws somewhere safe.
    • If the fasteners will not come up, use two flathead screwdrivers on either side of the fastener to remove.
  4. 2007-2012 Jeep Wrangler Headlight Replacement: passo 4, immagine 1 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 4, immagine 2 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 4, immagine 3 di 3
    • Locate right and left blinker lights under the fenders.
    • Twist blinker light toward the ground, and make sure you pull the bulb out carefully.
    • Make sure you are handling bulb carefully.
  5. 2007-2012 Jeep Wrangler Headlight Replacement: passo 5, immagine 1 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 5, immagine 2 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 5, immagine 3 di 3
    • Make sure all fasteners are removed from top of the grill, and the top of the grill is loose.
    • Firmly pull the bottom of the grill until the grill disconnects from the jeep.
  6. 2007-2012 Jeep Wrangler Headlight Replacement: passo 6, immagine 1 di 2 2007-2012 Jeep Wrangler Headlight Replacement: passo 6, immagine 2 di 2
    • Locate the 4 screws holding the headlight in place.
    • Use a star bit screwdriver to unscrew the .164-18 x .625 mm star bit screws around the headlight, and make sure you place screws somewhere safe.
    • Hold the headlight when unscrewing last screw to prevent the headlight from falling.
  7. 2007-2012 Jeep Wrangler Headlight Replacement: passo 7, immagine 1 di 2 2007-2012 Jeep Wrangler Headlight Replacement: passo 7, immagine 2 di 2
    • Use your hands to carefully remove silver ring from the headlight.
  8. 2007-2012 Jeep Wrangler Headlight Replacement: passo 8, immagine 1 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 8, immagine 2 di 3 2007-2012 Jeep Wrangler Headlight Replacement: passo 8, immagine 3 di 3
    • Locate red tab on the headlight plug connector, and push it away from the headlight.
    • Firmly pull the connector away from headlight to remove.
Conclusione
Altre 6 persone hanno completato questa guida.
Marco Santini
Membro da: 09/29/15
290 Reputazione
1 Guida realizzata
Cal Poly, Team 17-3, Green Fall 2015 Membro di Cal Poly, Team 17-3, Green Fall 2015
CPSU-GREEN-F15S17G3
4 Membri
3 Guide realizzate
3 Commenti
Could Jeep make it more difficult to do simple maintenance? I doubt it!
Linda Procida - Replica
What is that green connector called? I’m having trouble putting new lights because none of the converters fit.
Alex - Replica
What it is the recommended torque to screw it back?
Luis Vitorio Cargnini - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 49
Tutti i Tempi: 20,576
