Salta al contenuto principale
2006 Iron Horse Warrior Rear Wheel Replacement
  1. 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: passo 1, immagine 1 di 2 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: passo 1, immagine 2 di 2
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
  2. 2006 Iron Horse Warrior Rear Wheel Replacement: passo 2, immagine 1 di 2 2006 Iron Horse Warrior Rear Wheel Replacement: passo 2, immagine 2 di 2
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
  3. 2006 Iron Horse Warrior Rear Wheel Replacement: passo 3, immagine 1 di 2 2006 Iron Horse Warrior Rear Wheel Replacement: passo 3, immagine 2 di 2
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
Conclusione
Cal Poly, Team 15-2, Amido Spring 2015 Membro di Cal Poly, Team 15-2, Amido Spring 2015
CPSU-AMIDO-S15S15G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,122
