Salta al contenuto principale
2006 Ford F-150 Door Handle Cable Replacement
Cosa ti serve
  1. 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: passo 1, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: passo 1, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: passo 1, immagine 3 di 3
    • Remove the plastic cover from the door handle using a 7.6 cm slotted screwdriver.
    • Insert the screwdriver into the small opening found at the top of the plastic cover.
    • Carefully tilt the screwdriver upward to remove the plastic cover.
  2. 2006 Ford F-150 Door Handle Cable Replacement: passo 2, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 2, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 2, immagine 3 di 3
    • Remove the two 6 mm hex screws using a 6mm socket.
    • Turn the screwdriver counter-clockwise to loosen and remove the screws.
    • Grab the door handle and remove it from its location.
  3. 2006 Ford F-150 Door Handle Cable Replacement: passo 3, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 3, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 3, immagine 3 di 3
    • Remove the top plastic cover by pulling outward to snap it out of its location.
    • There are not any screws to remove in this part.
  4. 2006 Ford F-150 Door Handle Cable Replacement: passo 4, immagine 1 di 2 2006 Ford F-150 Door Handle Cable Replacement: passo 4, immagine 2 di 2
    • Remove the other plastic cover by pulling outward to snap it out of its location.
  5. 2006 Ford F-150 Door Handle Cable Replacement: passo 5, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 5, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 5, immagine 3 di 3
    • Remove the three 6 mm hex screws off the main door cover using a 6 mm socket. There are two screws at the top and one at the bottom.
    • The panel itself should stay in place even after the screws have been removed.
    • The door panel is maintained in place by plastic hooks behind it.
  6. 2006 Ford F-150 Door Handle Cable Replacement: passo 6, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 6, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 6, immagine 3 di 3
    • Gently, but with a strong force, lift the door cover about an inch or two high. Then, carefully pull it outward.
    • Be careful not to damage the plastic hooks that are keeping the door in place.
  7. 2006 Ford F-150 Door Handle Cable Replacement: passo 7, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 7, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 7, immagine 3 di 3
    • Snap out the upper end of the cable out of its location.
    • The upper end of the cable has a shape of a little ball. The little ball is found by where the door handle was removed.
    • Using a plier, lift the cable high enough so that the little ball can come out through the round opening above it.
  8. 2006 Ford F-150 Door Handle Cable Replacement: passo 8, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 8, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 8, immagine 3 di 3
    • Remove the three T27 hex star screws using a tamper torx screw driver. The screws are found at the bottom of the door.
    • You may need a mechanic creeper to lay under the door.
    • Wear protective goggles if you lay down under the door to do this step.
  9. 2006 Ford F-150 Door Handle Cable Replacement: passo 9, immagine 1 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 9, immagine 2 di 3 2006 Ford F-150 Door Handle Cable Replacement: passo 9, immagine 3 di 3
    • Insert your hand inside the bottom of the door to retrieve the door latch.
  10. 2006 Ford F-150 Door Handle Cable Replacement: passo 10, immagine 1 di 1
    • Remove the end of the cable out of its location.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 44
Tutti i Tempi: 1,996
