Salta al contenuto principale
2006-2008 Isuzu i-Series Wiper Motor Replacement
Cosa ti serve
  1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nut Caps: passo 1, immagine 1 di 1
    • Use a plastic prying tool or spudger to gently remove nut cap from wiper base.
  2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: passo 2, immagine 1 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: passo 2, immagine 2 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: passo 2, immagine 3 di 3
    • Use a 5/8 wrench or socket to remove the necessary nut holding the wiper in place.
  3. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: passo 3, immagine 1 di 2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: passo 3, immagine 2 di 2
    • Once the necessary nuts are removed, the wiper blade itself can be removed.
    • This can be done easiest by first flexing the wiper to the upright position, then gently pulling the wiper off of the screw.
  4. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: passo 4, immagine 1 di 2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: passo 4, immagine 2 di 2
    • Open the hood of the truck for easier access to the wiper cowl.
    • Using pliers, locate the six retainer clips on the plastic cowl and remove them by pulling straight up.
  5. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: passo 5, immagine 1 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: passo 5, immagine 2 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: passo 5, immagine 3 di 3
    • Position your hands underneath the wiper cowl and start to gently loosen the plastic from the windshield.
    • Pull straight towards the front of the truck to slide the wiper cowl over the screws that held the wiper blades, exposing the wiper components underneath.
    • The wiper cowl is flexible and can therefore be removed a little bit at a time. Take your time.
  6. 2006-2008 Isuzu i-Series Wiper Motor Replacement: passo 6, immagine 1 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement: passo 6, immagine 2 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement: passo 6, immagine 3 di 3
    • Locate the two screws on each side of the wiper assembly.
    • Use a 10mm socket or wrench and remove each screw.
  7. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: passo 7, immagine 1 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: passo 7, immagine 2 di 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: passo 7, immagine 3 di 3
    • Rotate assembly towards the windshield while starting to remove it from the truck.
    • Unplug the wiring harness located towards the driver's side of the truck.
    • The wire can then be fed through to remove the assembly the rest of the way.
  8. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: passo 8, immagine 1 di 2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: passo 8, immagine 2 di 2
    • Remove the connecting arm socket with a 1/2 inch wrench or socket (red circle).
    • Remove the three motor bolts with a 10mm wrench or socket (orange circles).
    • The wiper motor is now able to be replaced.
Conclusione
Altre 3 persone hanno completato questa guida.
Alex
Membro da: 10/08/14
211 Reputazione
1 Guida realizzata
USF Tampa, Team 1-9, Donnelly Fall 2014 Membro di USF Tampa, Team 1-9, Donnelly Fall 2014
USFT-DONNELLY-F14S1G9
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,949
