Salta al contenuto principale
2006-2011 Honda Civic Dome Light Replacement
Cosa ti serve
  1. 2006-2011 Honda Civic Dome Light Replacement, Dome Light: passo 1, immagine 1 di 2 2006-2011 Honda Civic Dome Light Replacement, Dome Light: passo 1, immagine 2 di 2
    • Before replacing the dome light and to avoid a short circuit, disconnect the car battery first.
    • Open the hood of your car by pressing the front latch and lift the hood.
    • Carefully attach the hood strut, (located towards the left of your car's engine), into the slot to hold the weight of the hood.
    • Disconnect the positive terminal of the battery in order to avoid short circuits.
  2. 2006-2011 Honda Civic Dome Light Replacement: passo 2, immagine 1 di 2 2006-2011 Honda Civic Dome Light Replacement: passo 2, immagine 2 di 2
    • Use a spudger and insert it into the space between the dome light cover and edge.
    • Gently pry the cover off but be careful that you don't break any of the clips attaching the cover to the assembly.
  3. 2006-2011 Honda Civic Dome Light Replacement: passo 3, immagine 1 di 1
    • Evaluate if the bulb is just loose or if it has burned out and needs to be replaced.
    • In this case, you can see that the bulb has turned black from the inside, indicating it has shorted out. This bulb needs to be replaced.
  4. 2006-2011 Honda Civic Dome Light Replacement: passo 4, immagine 1 di 2 2006-2011 Honda Civic Dome Light Replacement: passo 4, immagine 2 di 2
    • Use the spudger to detach the bulb from one end of the socket.
    • Pull the bulb out of the socket with the end that is loose.
  5. 2006-2011 Honda Civic Dome Light Replacement: passo 5, immagine 1 di 1
    • Align the new bulb with the socket and push it back into place.
    • Ensure the bulb is connected to each end of the socket or it will not function.
  6. 2006-2011 Honda Civic Dome Light Replacement: passo 6, immagine 1 di 3 2006-2011 Honda Civic Dome Light Replacement: passo 6, immagine 2 di 3 2006-2011 Honda Civic Dome Light Replacement: passo 6, immagine 3 di 3
    • Before attaching the cover of the dome light, reconnect the car battery carefully and test the light to make sure it works.
    • Align the tabs on the dome light cover with the holes in the assembly and push the cover back into place.
  7. 2006-2011 Honda Civic Dome Light Replacement: passo 7, immagine 1 di 1
    • You should now have a functioning dome light.
Conclusione
Hashim
Membro da: 10/17/22
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 74
Tutti i Tempi: 1,159
