Salta al contenuto principale
2006-2013 Toyota Corolla Ignition Coil Replacement
Cosa ti serve
  1. 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: passo 1, immagine 1 di 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: passo 1, immagine 2 di 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: passo 1, immagine 3 di 3
    • Pop the hood and remove the black plastic cover over the engine.
    • There is nothing to unscrew, or unlatch, and the cover should lift off. Once removed, the top of the engine will look like the third picture
  2. 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 2, immagine 1 di 2 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 2, immagine 2 di 2
    • Unplug the ignition coil you wish to replace. The coils are numbered one though four, left to right.
    • Do not unscrew the bolt on the ignition coil before this step. It makes the electrical plug more difficult to remove
  3. 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 3, immagine 1 di 1
    • Unscrew the bolt of the coil that needs to be replaced.
    • Be sure to put the bolt in a place you will not lose it!
  4. 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 4, immagine 1 di 2 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 4, immagine 2 di 2
    • Pull the coil straight up and out. It should come off of the spark plug with little resistance.
  5. 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 5, immagine 1 di 2 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 5, immagine 2 di 2
    • Apply a pea-sized amount of grease to the new ignition coil. It should be all around the rubber tip around the bottom.
    • While not required, this step will make any future replacements much easier.
  6. 2006-2013 Toyota Corolla Ignition Coil Replacement: passo 6, immagine 1 di 1
    • When inserting the new ignition coil, press down lightly to ensure it is completely in place.
    • Re-plugging in the ignition coil, and re-screw it in. This can be preformed in either order.
    • Repeat steps three through five as necessary for the other three ignition coils.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 69
Ultimi 30 Giorni: 323
Tutti i Tempi: 1,572
