Salta al contenuto principale
2006-2014 GMC Yukon LED Dome Light Replacement
Cosa ti serve
  1. 2006-2014 GMC Yukon LED Dome Light Replacement, Dome Light: passo 1, immagine 1 di 3 2006-2014 GMC Yukon LED Dome Light Replacement, Dome Light: passo 1, immagine 2 di 3 2006-2014 GMC Yukon LED Dome Light Replacement, Dome Light: passo 1, immagine 3 di 3
    • locate the square slots furthest from the light switch and wedge the edge of the prying tool into the slot to pry out the hooks holding the lens in place.
  2. 2006-2014 GMC Yukon LED Dome Light Replacement: passo 2, immagine 1 di 2 2006-2014 GMC Yukon LED Dome Light Replacement: passo 2, immagine 2 di 2
    • The back two hooks have been removed from their slots; pull the lens out to get the front hooks out of their slots.
    • The LED light could be hot depending on the amount of time you had the light on.
    • If your lights have not been on, feel free to pull the LED light out with your hand and replace it with your new one.
  3. 2006-2014 GMC Yukon LED Dome Light Replacement: passo 3, immagine 1 di 2 2006-2014 GMC Yukon LED Dome Light Replacement: passo 3, immagine 2 di 2
    • While removing the LED light you can either use a prying tool to hook the top edge of the LED and pull it down slowly or you can pull it down from the glass piece.
    • Insert your new LED light in the same place where the old one used to be.
    • Make sure that the copper components of the LED are aligned with the copper hooks that will keep the LED in place.
  4. 2006-2014 GMC Yukon LED Dome Light Replacement: passo 4, immagine 1 di 2 2006-2014 GMC Yukon LED Dome Light Replacement: passo 4, immagine 2 di 2
    • To put the lens back in, insert the hooks closes to the light switches into their respective slots first.
    • Insert the back two hooks in their respective slots.
    • You can use the prying tool to make it easier to insert the back two hooks in their slots.
Conclusione
hope this guide has helped someone!
J C
Membro da: 09/24/23
115 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 165
