Salta al contenuto principale
2005 Mustang GT Serpentine Belt Tensioner Replacement
Cosa ti serve
  1. 2005 Mustang GT Serpentine Belt Tensioner Replacement, Serpentine Belt Tensioner: passo 1, immagine 1 di 1
    • To open the hood, pull the hood latch located on the left side of the driver's foot well.
  2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 2, immagine 1 di 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 2, immagine 2 di 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 2, immagine 3 di 3
    • Push a lever (located just above the horse in the grill) to the left.
    • Lift the hood up, pull the prop out, and insert it into the hole on the hood labeled "prop."
  3. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 3, immagine 1 di 2 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery using an 8 mm socket and 3/8 inch drive ratchet.
  4. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 4, immagine 1 di 1
    • Loosen the band clamp on the throttle body with a flathead screwdriver.
  5. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 5, immagine 1 di 1
    • Loosen the band clamp on the air filter or airbox.
  6. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 6, immagine 1 di 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 6, immagine 2 di 3 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 6, immagine 3 di 3
    • Pull the intake tube back and to the left to remove it from the throttle body and airbox.
    • Place the intake tube out of the way
  7. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 7, immagine 1 di 1
    • Make note of the orientation that the serpentine belt runs. If the tensioner is broken, and the belt is no longer on, refer to a diagram for the vehicle. If still attached, release tension on the belt using a 1/2 inch breaker bar turned in the clockwise direction and remove it.
  8. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 8, immagine 1 di 1
    • Remove the three 10 mm bolts with your 3/8 drive and 10 mm socket.
    • Remove the tensioner.
  9. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 9, immagine 1 di 1
    • Install the new tensioner and torque the bolts to 20ft lbs. then using the breaker bar turn clockwise to allow the reinstallation of the belt.
    • Using the breaker bar, turn clockwise to allow the reinstallation of the belt.
  10. 2005 Mustang GT Serpentine Belt Tensioner Replacement: passo 10, immagine 1 di 1
    • Make sure all the grooves of the pullies are seated in the belt correctly, then release the tensioner to seat the belt.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 56
Tutti i Tempi: 2,425
