Salta al contenuto principale
2005 Honda CR-V Car Visor Replacement
Cosa ti serve
  1. 2005 Honda CR-V Car Visor Replacement, Car Visor: passo 1, immagine 1 di 2 2005 Honda CR-V Car Visor Replacement, Car Visor: passo 1, immagine 2 di 2
    • Ensure that the car is parked and utilize the parking brake.
    • Press the switch on the left of the parking lever, pull it outwards, and release it when it is fixed and outward.
  2. 2005 Honda CR-V Car Visor Replacement: passo 2, immagine 1 di 2 2005 Honda CR-V Car Visor Replacement: passo 2, immagine 2 di 2
    • Remove the outer shell with a spudger.
    • When the outer shell is loose enough, remove it with your hand.
  3. 2005 Honda CR-V Car Visor Replacement: passo 3, immagine 1 di 3 2005 Honda CR-V Car Visor Replacement: passo 3, immagine 2 di 3 2005 Honda CR-V Car Visor Replacement: passo 3, immagine 3 di 3
    • Remove the two 4.5 mm screws from the visor with a Torx screwdriver.
    • After removing the inner layer, the sun visor is now released.
  4. 2005 Honda CR-V Car Visor Replacement: passo 4, immagine 1 di 2 2005 Honda CR-V Car Visor Replacement: passo 4, immagine 2 di 2
    • Put the 4.5 mm screw removed in the previous step in the new sun visor.
    • Tighten the screw using a Torx screwdriver.
    • Also, note that the shape of the shell is aligned with the form of the hole in the roof.
  5. 2005 Honda CR-V Car Visor Replacement: passo 5, immagine 1 di 2 2005 Honda CR-V Car Visor Replacement: passo 5, immagine 2 di 2
    • Screw in the rest of the 4.5 mm screws back in the sun visor using a Torx screwdriver.
    • Ensure that the screws are tight.
  6. 2005 Honda CR-V Car Visor Replacement: passo 6, immagine 1 di 3 2005 Honda CR-V Car Visor Replacement: passo 6, immagine 2 di 3 2005 Honda CR-V Car Visor Replacement: passo 6, immagine 3 di 3
    • Put the outer shell back on top of the inner shell.
    • Finally, ensure that the sun visor can be moved to the driver-side window and twisted upwards and downwards.
Conclusione
To replace the new sun visor with the old sun visor, follow these steps in the same order.
An Chen
Membro da: 04/05/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 41
Tutti i Tempi: 497
