Introduzione
Your hood stays closed while driving thanks to two latches. One of the latches is activated by a lever inside your car, and the other is activated by pulling a lever on the front of your hood. Both latches must be activated in order to open the hood.
Pneumatic braces are used to hold your hood open while you work on your engine. These braces are only effective for a certain range of motion and are designed to only hold the weight of your hood. Proper use insures your safety.
Identify the open hood latch. It is located to the left of your brake pedal.
Pull latch toward you. You should hear a click from the front of the car.
To close hood, lower to 6 inches above engine, then drop hood. If you do not hear the latch reengage, push down on hood or try dropping hood from a higher level.
Altre 4 persone hanno completato questa guida.
2 Commenti
Don’t you think that people usually access this guide when the hood is stuck closed? In which case these instructions are no more helpful than those in the owner’s manual. I’ve opened the hood of my 2005 Honda Civic countless times, until this morning. Interior release functions just fine, but the secondary release does nothing.
Cable from inside hood release is broken need diagrams to show mechanism under driver's side fender to show how to replace it.
