Salta al contenuto principale
2005 Honda Accord Engine Oil Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. 2005 Honda Accord Engine Oil Replacement, Using a Jack: passo 1, immagine 1 di 2 2005 Honda Accord Engine Oil Replacement, Using a Jack: passo 1, immagine 2 di 2
    • Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
    • Place the Hydraulic Jack beneath the jack point.
    • Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
    • Continue pumping the lever until the wheels are two inches off the ground.
  2. 2005 Honda Accord Engine Oil Replacement: passo 2, immagine 1 di 2 2005 Honda Accord Engine Oil Replacement: passo 2, immagine 2 di 2
    • Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
    • Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
    • After fully lowering the Hydraulic Jack, remove it from underneath your car.
  3. 2005 Honda Accord Engine Oil Replacement, 2005 Honda Accord Opening Hood Guide: passo 3, immagine 1 di 2 2005 Honda Accord Engine Oil Replacement, 2005 Honda Accord Opening Hood Guide: passo 3, immagine 2 di 2
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  4. 2005 Honda Accord Engine Oil Replacement: passo 4, immagine 1 di 3 2005 Honda Accord Engine Oil Replacement: passo 4, immagine 2 di 3 2005 Honda Accord Engine Oil Replacement: passo 4, immagine 3 di 3
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  5. 2005 Honda Accord Engine Oil Replacement, Engine Oil: passo 5, immagine 1 di 2 2005 Honda Accord Engine Oil Replacement, Engine Oil: passo 5, immagine 2 di 2
    • Pull out the dipstick
    • Unscrew the cap from the oil tank
    • Set both aside. lay a towel over the engine block and set dipstick and the cap on that to avoid traces of oil.
  6. 2005 Honda Accord Engine Oil Replacement: passo 6, immagine 1 di 3 2005 Honda Accord Engine Oil Replacement: passo 6, immagine 2 di 3 2005 Honda Accord Engine Oil Replacement: passo 6, immagine 3 di 3
    • Place oil pan between the front tires
    • Lay down and slide yourself headfirst under the front of the car. To the side of the right tire you will see the oil tank.
    • Loosen the drain bolt with a 17mm wrench. Once loose, use your hand to unscrew the rest of the way.
    • Once the bolt is removed, oil will pour out of the hole very quickly. Position the oil pan under the hole before completely removing the screw.
    • Allow oil to drain until the flow is reduced to a slow drip.
  7. 2005 Honda Accord Engine Oil Replacement: passo 7, immagine 1 di 2 2005 Honda Accord Engine Oil Replacement: passo 7, immagine 2 di 2
    • Replace the crush washer on the drain bolt with a new one.
    • Put the drain bolt back into the oil tank and tighten with 29 ft-lb of torque.
  8. 2005 Honda Accord Engine Oil Replacement: passo 8, immagine 1 di 1
    • Using a funnel, pour the new oil into the oil tank.
    • Honda recommends using 4 quarts of their synthetic blend 5w-20 Motor oil.
  9. 2005 Honda Accord Engine Oil Replacement: passo 9, immagine 1 di 3 2005 Honda Accord Engine Oil Replacement: passo 9, immagine 2 di 3 2005 Honda Accord Engine Oil Replacement: passo 9, immagine 3 di 3
    • Put the dipstick back in.
    • Put the oil tank cap back on.
    • close the hood.
Linea Traguardo
Altre 5 persone hanno completato questa guida.
Frank
Membro da: 04/14/14
291 Reputazione
2 Guide realizzate
Cal Poly, Team 12-35, Maness Spring 2014 Membro di Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Membri
5 Guide realizzate
2 Commenti
Thanks. I was never able to find the oil filter before. Note that the Honda owner's manual lists oil capacity at 4.5 quarts, whereas you say 4 quarts; I don't know if this makes a difference.
JMY - Replica
Well-done.
The only issue I have is that I don't have the tools.
The explanations are ok
Olayinka Erinfolami - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 99
Tutti i Tempi: 49,952
