Introduzione
I hope this guide will help you in changing your 2005 Chevrolet Tahoe’s alternator. All of the tools and required parts are listed in this guide as well as pictures to help demonstrate what is happening in each step.
The alternator in a vehicle charges the battery while the car is running. If your alternator goes out, your battery will die, leading to your car not turning on. It is important to replace the alternator for proper function of your car. Be cautious and make sure to follow the steps in order to prevent injury. When working on something in a vehicle, it is always important to disconnect the negative terminal of the battery. Always let your vehicle cool down before trying to work on it. Wait at least two hours from the previous time it was driven before attempting to work. This guide will have your vehicle back in business within an hour if all goes well.
Thank you for viewing this guide; I hope it helps!
Cosa ti serve
Pop your hood by pulling out on the lever that is to the left of the emergency brake pedal.
Once the lever is pulled, go to the front of the vehicle and lift up on the lever that is under the center of your hood.
Realign the belt into its proper position.
Place the belt in between your 15 mm socket and the tensioner.
Turn the tensioner to the right to relieve the tension and place the belt back on.
Once you have done this, release the pressure you are applying to the tensioner and make sure that the belt is properly aligned.
